lifeonmars
Message 1 of 12
How Do You clear fault banners on your account ?
This morning I checked my line due to an email problem,
I have a banner on my home page stating I have a fault, however I click on the fault and the banner says there are no faults to display.
Again the same thing occurs when I check my line on the web page ?Screenshot 2019-10-27 at 10.56.03.png
11 REPLIES 11
DanielS
Moderator
Moderator
Message 2 of 12
Re: How Do You clear fault banners on your account ?
Hi @lifeonmars,
There may be a fault still open on your account that we need to close off. Would you like us to check it for you and shut it down if needed?
Just so you know, I've edited your pics to remove some of your personal info 🙂
DanielS
lifeonmars
Message 3 of 12
Many Thanks, and Yes please.  I think I pressed the wrong button all I wished to do was check speed but eventually ended  up with that fault report .   I am also trying to get BT wifi deactivated but still showing Activated on router.
DanielS
Moderator
Moderator
Message 4 of 12
You are very welcome.
Thanks for replying to my private message.
Have you tried deactivating BT Wifi through your MyBT login at MyBT? Log in, click on Manage extras and then Manage BT Wi-Fi.
On the next page, you'll need to scroll down and click on Opt out of BT Wi-Fi.
DanielS
lifeonmars
Message 5 of 12
Yes, Thanks Daniel
Have already done that, to no avail, although some say you have to wait 28days or more !!!!  Mines been  only 14days
DanielS
Moderator
Moderator
Message 6 of 12
It can take up to 28 days to be completely removed. When you go to the page I mentioned it should give you an option to opt back in.
Has the banner disappeared for you now?
DanielS
lifeonmars
Message 7 of 12
Unfortunately not Daniel
DanielS
Moderator
Moderator
Message 8 of 12
Thank you.
It has been closed at our end. It may take until Monday for it to clear but it is 100% closed now.
DanielS
lifeonmars
Message 9 of 12
Unfortunately even after clearing history and cookies etc the Banner is still showing  on my homepage. ?
NeilO
Moderator
Moderator
Message 10 of 12
Hi @lifeonmars I see you've sent over your details and they're in our queue waiting to be picked up. We'll be happy to get that looked into once you reach the top of our list, once the fault it closed on our side it should eventually filter through to MyBT and close there.
