Jhutson2491
Message 1 of 3
How do I check for line cord error on a BT6500 phone
2 REPLIES 2
pompey1898
Recognised Expert
Message 2 of 3
Re: How do I check for line cord error on a BT6500 phone
Hi @Jhutson2491 ,
I'm not sure what you mean as your post is blank ?
If you are saying you get a line cord error on your phone, try disconnecting your base from the power socket for 30 seconds.
Devon_Dave
Distinguished Guru
Message 3 of 3
A line cord error can also be caused by no dial tone on your line. May also be worth checking with a known working corded phone.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
