Gracie2
Message 1 of 4
How long will it take to install a new line?
Hello,
ive got an appointment to have an engineer install a new line at my flat on Friday. When they arrive, what do they need to do and how long will it take roughly?
thanks.
3 REPLIES 3
Keith_Beddoe
Message 2 of 4
Re: How long will it take to install a new line?
@Gracie2 wrote:
Hello,
thanks.
Based on your last thread about there only being a VM box fitted, then it may take a couple of hours, depending on where the main Openreach network connection is located. Its not really possible to say.
Gracie2
Message 3 of 4
Sorry if it’s a silly question. But I need to know as my workplace are asking me.
Keith_Beddoe
Message 4 of 4
There is no way of knowing, as each job is different.
If you are in a large apartment complex, then there would be a central distribution point where an internal cable would have to be run from, if one does not already exist.
