bingefeller
Message 1 of 2
How to disable BT Text on my landline?
I dialled 0800 587 5252 and it only gave me the option to set curfews, which I don't want to do - I want to disable the calls completely.
1 REPLY 1
Devon_Dave
Distinguished Guru
Message 2 of 2
Re: How to disable BT Text on my landline?
From your landline, dial 0800 587 5252
Select Option 1, then Option 5 to disable all messages.
Your request should be activated within 30 minutes.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
