Message 31 of 32
Re: I can't connect to Digital Voice
Hi @Jillity, thanks for checking that and posting back. I also don't think it was sent as it has been out of stock for a while now. The team has told me they are expecting stock very soon so please check on that open order as I'm sure it's open awaiting the stock to arrive. I'll see if I can find a date for the stock and post back to you.
cheers
John
Message 32 of 32
Ok thank you.
