Message 1 of 7
INSTALLATION OF DIGITL VOICE DELAYED
I bet there is nobody out there who has waited since 6 October 2025 for Openreach to instal Digital Voice. Still haven't got a date for installation from BT or Opereach.  What a farce!
6 REPLIES 6
Message 2 of 7
Re: INSTALLATION OF DIGITL VOICE DELAYED
How many times have you requested an installation date since 6 October 2025?
Message 3 of 7
Do you mean digital voice or full fibre?
Message 4 of 7
Most people posting on this forum complain that they HAVE been moved to DV rather than they haven't. Not sure why its such a big deal that you haven't.
Message 5 of 7
Digital Voice AND FUll Fibre
Message 6 of 7
Your first post says Digital Voice.
Just so you are aware, they are separate issues.  Despite the marketing hype, Digital Voice will run quite happily over copper and does not necessarily need Full Fibre to be installed.
Message 7 of 7
Digital Voice is a BT ‘product’ and if your PSTN telephony is working , then what’s the problem, it will be replaced by DV by the end of January 2027 and for most is a simple process, you are advised of the actual data of change  and move your phone cord from the wall socket to the router socket .
FTTP has nothing to do with BT but Openreach , so posting here about the date Openreach will have FTTP available in your area is pointless.
As stated DV doesn’t need FTTP it works on ADSL and FTTC as well as FTTP , you don’t need FTTP for DV .
