tuner30
Message 1 of 3
If the external pair is crossed on my NTE5 would it effect my landline?
When having an extension built my builder removed my NTE5. he replaced it after the build was completed, however my nternet works but my landline does not. the phone displays a message saying check the landline lead. since the internet is working, could this be a simple case of crossed wires?
2 REPLIES 2
licquorice
Message 2 of 3
Re: If the external pair is crossed on my NTE5 would it effect my landline?
No, polarity is irrelevant. However, did he connect the wires to the correct terminals. Is it a single socket with an external filter or a filtered faceplate with separate sockets for phone and broadband?
Devon_Dave
Distinguished Guru
Message 3 of 3
Do you actually have a dialtone on the line? Maybe worth checking with a known working corded phone into the test point of your main socket.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
