Lucgil
Message 1 of 4
Landline
Hi - I am buying a property and dont know whether there is an active land line to the property?  It has been empty for over 5 years and the previous occupant only used a mobile phone.  I would like a landline and broadband installed as soon as I can?
How do I find out?  I don't have access to the property currently.
3 REPLIES 3
imjolly
Message 2 of 4
Re: Landline
the landline will not be active although the line will still be there   you need to place an order with whichever ISP you decide
Lucgil
Message 3 of 4
Re: Landline
Do I need to know the previous phone number or need a new line installed?
Keith_Beddoe
Message 4 of 4
Re: Landline
You will need to place a new order for a landline, the old number would not be available.
Place an order for a line only using this link - https://www.bt.com/landline/deals
That is assuming you want to use BT.
If you want broadband as well, then you may need to wait until the phone line is working first.
