Message 1 of 5
Managing voicemail online
Hi all, I used to be able to manage my voicemail online so when I was away, I could set it, or If i was on a day off I could set it for calls to be diverted for a period of time. Is this still a function as I cant see it anymore?
Steve
4 REPLIES 4
Message 2 of 5
Re: Managing voicemail online
Message 3 of 5
Thanks, but this is of no help
Message 4 of 5
Try logging onto your MyBT the Your Products.
If you can not find how to do what you want to do there it will most likely mean that that function is no longer available.
Message 5 of 5
Done that thanks, assuming it's a gonner!
Cheers
