TwoFingerTyper
Message 1 of 17
Massive increase in scam calls
Hi all,
Over the past few days I have had a huge increase in calls from scam numbers reporting to be from various places (and each time on a different number) and wondered if this was a UK-wide surge or if I am just lucky?
Number has been registered on TPS, had never been in a directory, etc - so a mystery as why it's all of a sudden become so popular.
Is there a BT service that cuts these off or only allows approved numbers?
Thanks,
TFT
16 REPLIES 16
imjolly
Message 2 of 17
Re: Massive increase in scam calls
not being listed in a directory is immaterial as all the numbers are computer generated and often in sequence
you may find this post useful  https://community.bt.com/t5/Landline/quot-Spoof-quot-Number-Blocking/td-p/1981690
Studon
Message 3 of 17
If I get a silent scam call, I say "Alexa trace this call"
Click, line clears, NU heard
Studon
pompey1898
Recognised Expert
Message 4 of 17
@TwoFingerTyperwrote:
Hi all,
Thanks,
TFT
Hi @TwoFingerTyper ,
Have you got BT Call Protect ?  If not, then get it as it does cut down the number of unwanted calls.
If you want to reduce them to nil get a call guardian phone.
TwoFingerTyper
Message 5 of 17
I thought I did, but I checked and it would seem not! I have now activated it so hopefully an instant reduction in calls and I can then look at the other methods suggested in this thread should they continue to be as frequent.
Message 6 of 17
You might like to have a read through this thread:
https://community.bt.com/t5/Landline/Phone-Scams-Using-quot-Spoofed-quot-Numbers-What-is-Being-Done/...
Without being defeatist, there is a limited amount that can be done with scammers seemingly having the advantage over current defensive measures available on landlines - unless you are prepared to take the route adopted by some which a type of reverse psychology i.e. set up your landline only to allow specifically saved numbers and block everything else (using a paid subscription service with a VIP list).
pompey1898
Recognised Expert
Message 7 of 17
Or get a call blocking phone.  I know there is an expense but if you want zero calls ringing your phone then they solve it
Andy_N
Distinguished Guru
Message 8 of 17
Hi.
Unfortunately due to the scammers changing their spoofed number they call from (they know all about these types of blocking systems of course), it might only reduce the calls very slightly. Call Protect doesn't really work. It's like adding email spam to a blocking list of email addresses - they spoof them and change it, hence that method is next to useless too.
pompey1898
Recognised Expert
Message 9 of 17
Hi.
Hi @Andy_N ,
I hate having to disagree, to an extent, with an esteemed Guru.  Call Protect has worked for me by significantly reducing the number scam calls that have got though in the last 3 years.  I used to get about 5 to 10 per day.  Now it is about 1 or 2 a week.
Andy_N
Distinguished Guru
Message 10 of 17
That's great 👍
I'm sure everyone is different, and some might get calls from the same number repeatedly - hence Call Protect will work. My handset is set to block (well not ring) from international calls. Though it still shows as a missed call. So effectively that has reduced by a few the number of calls I receive. I don't typically get many anyway.
