malamute
Message 1 of 9
Master socket not working
Hi
I lived in my home which is a new build for 12 years and always used the extension socket in the living room for phone and BB which works fine.
we are having work done and i want to move the phone and BB to the master socket, problem is it doesn't work.  It also doesn't look like the NTE5 either.  Both sockets look like extension sockets.
My question is has this been installed wrongly and how do i fix it?Extension in the living roomExtension in the living roomMaster by the front door, other side of the wall from the  open reach boxMaster by the front door, other side of the wall from the open reach box
8 REPLIES 8
Keith_Beddoe
Message 2 of 9
Re: Master socket not working
@malamute
Who provides your phone and broadband service?
imjolly
Message 3 of 9
Do you have something like this fitted outside if so that is your master socket
licquorice
Message 4 of 9
It has been wired wrong. Disconnect the Orange wires in both sockets, they are not needed. The Blue wires go to pin 2 on both socket sand the wh/blue go to pin 5 on both sockets.
malamute
Message 5 of 9
BT provide my broadband
malamute
Message 6 of 9
Yes i do - so does that mean i don't need an NTE5 type socket?
imjolly
Message 7 of 9
Yes that is your master and internal sockets are only extensions.  Thought openreach were rewiring to instal a filtered master socket which also gave access to a test socket
malamute
Message 8 of 9
Thanks for your comment Liquorice.  It has worked in that the 'master' socket (not sure it is but...) is working now i have done what you suggested.  However when i make a call using a phone connected to this socket I loose my broadband which is still connected to the extension.  Tried it a few times and it seems to be related,  the board-band gets cut off when the phone call connects, then the board-band connects again when I end the call.  Any ideas why this should happen?
imjolly
Message 9 of 9
You need to use filters in both sockets
