Message 1 of 2
Mi rational with dual phone line.
I currently have two analogue phone lines one of which also supports FTTC broadband. If I migrate to Full Fibre then the first line will obviously migrate to DV but what happens to the second line ?  If it remains as an analogue line then not sure what happens to the 500 minutes calling plan which is shared across the two line currently, I suspect you cannot share a calling plan across analogue and DV simultaneously.
Anyone know how this works ?
Peter
1 REPLY 1
Message 2 of 2
Re: Mi rational with dual phone line.
Hi @peterh0001
Welcome to the community.
I believe the primary line would be migrated to Digital Voice, and the second line would remain on analogue, for now.
I'm not 100% on what would happen with the plan. My best advice is to call and speak with our Customer Support team. They'll be able to check your specific account and give you some better advice.
Please come back and share what happens.
Chris
