Message 1 of 3
More than one master socket on a PSTN line.
Hi all, sorry but I have yet another question.
My mum has an old BT master socket beside her desk upstairs where her phone line used to come in. She has since had a new line fitted downstairs on a completely new master socket. Therefore. The one upstairs is dead.
I was going to wire it up for her with telephone wire. Then stick a 431a plug on the end and plug it into a splitter on the master socket downstairs. Is it ok if I do this?
I know ideally I shouldn’t but would it cause any real trouble. I know having 2 ring capacitors on the line won’t be good, so maybe wiring a 231a might be better.
thanks
ryan
Regards
Ryan
If this reply was helpful, please leave a like, or if I answered your question, please click 'mark as answer. Many thanks
2 REPLIES 2
Message 2 of 3
Re: More than one master socket on a PSTN line.
I would do away with old master as only should be 1 master socket and replace with small extension socket and then connect to new master
Message 3 of 3
I have had problems when there have been 2 master sockets on one line - so I would also recommend having only one.  You can always open up the old one and simply snip out the 2 components present leaving it as a simple slave socket - done this many times (due to electricians installing master sockets everywhere when they were supposed to be slaves.
