Seniorhags
Message 1 of 10
Mystery landline number
Good evening - I am new to this community so please forgive any discourtesy or naivety. We had our intruder alarm serviced today and the engineer told us our alarm was not communicating with the monitoring service. This was a surprise to us as it had done in the past, being attached to our home landline.   It seems that  without any request from us, and until to day unknown to us, the intruder alarm line has been changed and is now attached to a different line, which is live although it  is barred to incoming and outgoing calls, with a different number appearing to be from our area. I did not recognise that number, nor have I ever paid for it, and we have lived here 38 years.  On contacting BT I have been told that the number "is not theirs", that they cannot discover who the supplier is, and that they cannot help me at all.  Has anybody else heard of anything like this?   Any advice or information would be greatly appreciated. Many thanks.
9 REPLIES 9
Keith_Beddoe
Message 2 of 10
Re: Mystery landline number
@Seniorhags
What are the first six digits of the phone number that your line is connected to? Do not post the full number here.
Its possible you have a crossed line.
Seniorhags
Message 3 of 10
Thanks for responding Keith.  The first six digits are: 01449 7
Keith_Beddoe
Message 4 of 10
That is a protected range of numbers, and is not allocated to any provider.
What number is read out on your phone, when you dial 17070?
Either way, you need to report a fault on your phone line by calling BT on 0800  800 151, and explain that you cannot make outgoing calls. They will pass the fault to Openreach, who will check the external routing back to the exchange.
Her is the result from the Ofcom database.
1449 97 0 Protected   4+6
1449 97 1 Protected   4+6
1449 97 2 Protected   4+6
1449 97 3 Protected   4+6
1449 97 4 Protected   4+6
1449 97 5 Protected   4+6
1449 97 6 Protected   4+6
1449 97 7 Protected   4+6
1449 97 8 Protected   4+6
1449 97 9 Protected   4+6
Paul608085
Expert
Message 5 of 10
@Keith_Beddoe
Haven't you got too many 9's there?
Keith_Beddoe
Message 6 of 10
@Paul608085 wrote:
@Keith_Beddoe
Possibly, let me check.
My mistake, but you will need to look at the next digits. Either way, you need to report that the landline number showing on your BT account, is the one that is not working. My guess is that your number has been crossed with a BT "stopped" line, which is why its not working.
1449 70 Allocated Gamma Telecom Holdings Ltd 4+6 08/03/2005
1449 71 Allocated BT 4+6 15/07/1994
1449 72 Allocated BT 4+6 15/07/1994
1449 73 Allocated BT 4+6 15/07/1994
1449 74 Allocated BT 4+6 15/07/1994
1449 75 0 Protected   4+6
1449 75 1 Protected   4+6
1449 75 2 Protected   4+6
1449 75 3 Protected   4+6
1449 75 4 Protected   4+6
1449 75 5 Protected   4+6
1449 75 6 Protected   4+6
1449 75 7 Protected   4+6
1449 75 8 Protected   4+6
1449 75 9 Protected   4+6
1449 76 Allocated BT 4+6 15/07/1994
1449 77 Allocated BT 4+6 15/07/1994
1449 78 Allocated BT 4+6 15/07/1994
1449 79 Allocated Magrathea Telecommunications Limited 4+6 24/09/2004
Seniorhags
Message 7 of 10
Sorry chaps - had a fierce storm here so switched off to protect the computer. Our number starts with 1449 736...  which according to the table you sent is allocated to BT. Our problem is that the line connected internally and solely to the Alarm system is not our number.  Our own line which is our broadband as well is working perfectly, and so I am not sure I can report a fault on it.  However, I will take your advice and will try and ring tomorrow. I must confess that although BT has served us pretty well all these years, when something goes wrong it can be next to impossible to sort out, and the prospect of phoning BT is not one I will look forward to. In the meantime thanks very much for your help and interest and I will update this if I have any joy tomorrow.
Keith_Beddoe
Message 8 of 10
You need to report that there is a fault on the number which is allocated to the alarm system. You must be paying line rental on it, so the number should show on your BT account.
It should be a simple task for Openreach to check the number, as although its wired to the alarm unit, there should be a test socket somewhere. Its probably some crossed wires on the external network.
Devon_Dave
Distinguished Guru
Message 9 of 10
Whatever the phone number you have attached to the alarm, if the alarm gets activated it would still dial out. Unless the line is out going calls barred.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Devon_Dave
Distinguished Guru
Message 10 of 10
Doh, just read the complete post regarding the OCB line. Was  a late night
