I am working on a development where a property is being changed from 1 unit into 5
The existing house has a dedicated line and the previous business had I believe a telephone line (may be two lines), a fax line and broadband.
The proposal involves conversion of the existing building into 5 No. units and 3 No. plots.
Please can you confirm what we need to do to start the process for having these installed?
Solved! Go to Solution.
Hi, @LB111 Thanks for your post, this is something that you need to contact Openreach about. You'll get details of how to register the site on this link.
Neil
Thank you 👍
