Message 1 of 10
New phone line
I have a connection from the telephone pole to my house, but no bt socket in the house
Does anyone know how to get one installed and who I should contact. Also how much does it cost
9 REPLIES 9
Message 2 of 10
Re: New phone line
If you have a connection from the pole to the property where does the cable terminate, is there any Openreach box or unit in the property?
Do you have something like this?
Message 3 of 10
Re: New phone line
 this is were the cable ends
We have lived in the house for 20 years and always used virgin for broadband. But its gone to expensive and I am looking for a better deal
Message 4 of 10
Re: New phone line
Just order from your chosen supplier and whatever is required will be installed. What is there currently is pretty much irrelevant.
Message 5 of 10
Re: New phone line
@Mado21 Whichever provider you use, will ask Openreach to fit a socket as part of the order.
Message 6 of 10
Re: New phone line
I know that there would be a setup fee from my new supplier, but Would there be any charge from openreach
Message 7 of 10
Re: New phone line
The ISP cost which you would pay and the ISP settle with openreach. You don't pay openreach
Are you getting broadband as well?
Message 8 of 10
Re: New phone line
I would be getting broadband, has any one got a idea of cost
Message 9 of 10
Re: New phone line
Message 10 of 10
Re: New phone line
If you enter your address this will show what type of broadband connection is available to you which will then help make decision of which package
