judy2
Message 1 of 11
No incoming calls on landline AND wifi cuts out when making an outgoing call from landline
Four weeks ago i had a BT engineer out because my internet stopped working when i made an outgoing call. He thought the issue was to do with my other phone socket extension. This fixed the problem - but i only have one phone socket now.
This problem has now returned with wifi stopping when i pick up the phone to diall out. And now no incoming calls either.  It comes up as an "invalid number" on the callers side.
Any ideas?
10 REPLIES 10
imjolly
Message 2 of 11
Re: No incoming calls on landline AND wifi cuts out when making an outgoing call from landline
do you get a dial tone?  if so is it silent no line noise?
Keith_Beddoe
Message 3 of 11
It would have been a Field Technician from Openreach that visited, not BT Retail.
I assume you are a BT Retail customer?
If you dial 1470 17070 you should get your phone number read out to you. Can you confirm that the number that is read out, matches your home phone number?
judy2
Message 4 of 11
Hi
I can make an outgoing call but the line is noisy...it sounds like a fax machine line dialling up and trying to connect over and over.
judy2
Message 5 of 11
I am a BT customer and have been for many years. I called that number you suggested and it is the correct phone number.
Keith_Beddoe
Message 6 of 11
@judy2 wrote:
Hi
Then you have a fault on your phone line which you will need to report as a noisy line.
Check at the test socket first, just to make sure the fault is external.
judy2
Message 7 of 11
Sorry, how do i check at the test socket?
Keith_Beddoe
Message 8 of 11
What does your master phone socket look like?
Master socket with one socket
Or
Master socket with two sockets
judy2
Message 9 of 11
openreach with one socket
imjolly
Message 10 of 11
then remove bottom half ans test socket should then be visible  if you connect phone there and still noisy then report phone fault to 151
