PaddyB
Moderator
Moderator
Message 11 of 11
Re: No incoming calls on landline AND wifi cuts out when making an outgoing call from landline
Hi @judy2,
Have you had a chance to try the test socket as suggested @imjolly  and @Keith_Beddoe? If there was still noise on the line that would indicate that there is a fault on the network and an engineer would likely be needed.
If you need any help in arranging and engineer, please post back as I'd be more than happy to help.
PaddyB
