ahmsajid
Message 11 of 18
Re: No wiring inside Master Socket
@StarwireLooking at your answer it seems like my property is wired and an engineer visit is not required. However, I connected my router within the socket and I can see the purple light is just flashing.
imjolly
Message 12 of 18
First thing is if you connect a phone do you get a dial tone.  You need dial tone before you can get fibre
ahmsajid
Message 13 of 18
Ahhh ok. Then I need to wait till tomorrow. Since I am with Virgin Media I never needed a phone. I have ordered a phone hopefully will receive it tomorrow. I can do a quick check tomorrow and provide my feedback here. I really appreciate your respose trying to provide a solution
Mateen46
Message 14 of 18
Hi All,
I'm in the same boat as ahmsajid.
I've inserted the phone line directly in the test socket as instructed. However, there's still no dial tone and the line's still dead.
Is there anything else that I can do myself to fix it, before I call for help from the unresponsive BT support number?
ahmsajid
Message 15 of 18
@Mateen46I am relieved to hear that I am not the only one having this problem.
My new broadband installation date was on 30th March, but Openreach currently put  onhold all home visits due to COVID-19 situation.
So I assume there may be a socket but it may not be connected to the cabinet.
I guess Openreach can connect my home without a visit, but not sure why they haven't done that. Anways I am still waiting for my landphone to be delivered tomorrow. Crossing my fingers that I can get a dial tone. Maybe putting my hopes too high 😜
ahmsajid
Message 16 of 18
@imjollyI connected the phone today and do not hear any dial tone. So this explains that my property does not have a phone connection. Even though the Master socket have AB terminals connected - does the Openreach engineers need to come and visit my property for installation?
Can't they connect my premises from the cabinet?
Devon_Dave
Distinguished Guru
Message 17 of 18
In both cases the engineer may need to get into your premises to plug a tracking tone into your phone socket. He would then need to go to the Copper cabinet (PCP) and trace where your line is located in order to push dial tone through from the telephone exchange.
As has been mentioned openreach engineers are not currently going into customers premises due to Covid-19
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
ahmsajid
Message 18 of 18
@Devon_Dave thank you for your detailed answer. I will then wait for the engineers to resume their operations.
