Typhoo
Message 1 of 5
Personal blacklist
Every time that I've tried to add a recent call number to my personal blacklist, a red "error" banner pops up. I have been able to add none.
Any thoughts?
4 REPLIES 4
NeilO
Moderator
Moderator
Message 2 of 5
Re: Personal blacklist
Hi @Typhoo, welcome to the community and thanks for posting, sorry about that. Is the error banner pop up happening on every number you've tried or is it just the one number in particular? If you try typing in the number manually to the list do you get the same error?
Typhoo
Message 3 of 5
Hi NeilO,
Thanks for responding. It's on every number and also when I type a number in.
It's an "error - try again" message.
Typhoo
NeilO
Moderator
Moderator
Message 4 of 5
@Typhoo we'll need to get that looked into further as there may be a fault with your call protect service. I've sent you a private message so you can get in touch with the moderation team and we'll be happy to help.
Chris_Hibiscus
Message 5 of 5
I am having problems as well. While normal numbers can be added, withheld numbers fail.
Any reason for this? It used to work!
