Message 1 of 3
Phone intermittently not dialing-out
Compared with some of the problems on here this should be a very simple one!
We have a new BT phone which intermittently fails to dial the number at end of the dial-out sequence.
The phone is a BT one,brand new and the other phone suffered the same problem so not a phone problem.
The problem seems to be temporarily fixed by removing the phone line from the Master socket and replacing but problem returns later on.
Any help much appreciated!
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: Phone intermittently not dialing-out
Probably  poor line quality, or a faulty port on the exchange line card, which are well past their useful life, hence the pending move to BT Digital Voice.
You could try initiating a line test to see if it clears the problem. That causes a number of mechanical relays to operate on both the line card, and the Line Test System. This can clear high resistance relay contacts.
https://www.bt.com/help/report-and-track-your-bt-problem
See if it reports an issue.
Message 3 of 3
Many thanks for your prompt reply-will follow this-up and advise when solution found.
