Stethepea
Message 21 of 25
Re: Phone line not ringing?
I reset it when I was on the phone to them, the light stayed solid green for about 5 minutes & then went back to solid blue. But we didn't lose connection at all when resetting the hub, the BT person on the phone was confused too.
imjolly
Message 22 of 25
can't understand why to are not able to access hub manager as you do not need internet access just the wifi from the hub.  do you have an ethernet connection on a device
Stethepea
Message 23 of 25
But the person on the phone said that from their end the hub is showing as offline, could that effect it or?
& I'm using ethernet connection on my PC, I'll try on WIFI pc now & update you on that
Stethepea
Message 24 of 25
Even with WIFI it's just loading none stop, so no idea to be honest, the new hub should come friday so I honestly don't mind waiting.
But thanks for all the help, honestly it means alot!
imjolly
Message 25 of 25
no need for internet connection to get into hub manager especially when using ethernet.  I always when I get a new hub connect with ethernet before I connect it to internet so I can make my personal changes to SSID etc
