FrankVitali
Message 1 of 4
Phone line replaced. Auto dialers not working.
Hi all,
I have just had a new phone line put in. It replaces one that failed.  The box is a NTE5c. All the phones are working fine, a good strong dial tone, no crackles or hisses. Incoming calls and outgoing calls work fine.
However..
My alarm system which has a built-in auto-dialer is not working any more. It always used to work. I have checked voltage and there is 50.2. I even wired in a telephone socket at the alarm point and made sure there is dial tone. There is. Outgoing calls that I make from that point work fine.
When it is trying to dial out and I pick up a phone to listen in, I can here it trying to dial out but it is very low volume and once it's dialed the number automatically, the dial tone just continues.
I have also a SureSafe Personal Alarm which also has in built dialer and that is not working either. I have tested this by plugging it in direct to the Master Socket with nothing else plugged in and it still doesn't work.
Any thoughts how to fix would be appreciated,
3 REPLIES 3
iniltous
Recognised Expert
Message 2 of 4
Re: Phone line replaced. Auto dialers not working.
If your ‘line’ was installed  because the original failed , what was the cause of that failure ?, if it were a lightning strike, then it’s possible that your equipment connected to the line was damaged because of that....regardless, if your line is now OK , but your equipment isn’t working as expected, you would need to approach whoever provides that equipment for it to be checked and repaired or replaced as necessary
Keith_Beddoe
Message 3 of 4
@FrankVitali
Who provides your phone service?
Devon_Dave
Distinguished Guru
Message 4 of 4
When you monitor your auto dialler making a call is it sending out pulses or tones?
It could be that the new line does not allow pulse (known as loop disconnect)
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
