Message 1 of 4
I wish to connect my older phone to the rear of my new digital hub, I do not have the green plug adaptor for the phone connection. Where will I get one? Having spent £70+ on new digital phones with no answer machine I don't wish to spend too much more for another lame duck.
3 REPLIES 3
Message 2 of 4
Re: Phone
You need to have a SH2 and have moved to an active digital voice connection before you have and can use the green phone socket on back of hub
Message 3 of 4
Re: Phone
The socket on the back of the Smart Hub 2, is a standard phone socket,  just like your normal wall socket.
All new phones have the same connector, or would come with an adapter.
If your old phone only has an RJ11 plug on the end, then you would need an adapter like this.
Message 4 of 4
Re: Phone
Fantastic! You have sorted out my problem and phone working as it should. I am very grateful for your help.
