Message 1 of 4
Porting number away from Digital Voice to a VOIP supplier
What would happen to my Full Fibre contract with BT if a 3rd party VOIP supplier (eg like SIPGATE) requested the number being used by Digital Voice?
This is really 2 questions:
1. The contract implications
2. The effect on the Digital Voice service
In theory the DV could continue with a different number to the original one, but what would the process be to achieve this?
3 REPLIES 3
Message 2 of 4
Re: Porting number away from Digital Voice to a VOIP supplier
if you currently have BT contract for broadband and phone then
1  porting phone number to VOIP provider will end contract
2  you could then start a replacement contract for broadband only including line rental but no phone - so no DV
Message 3 of 4
Thanks for your reply. Has there been any change to this in the last year? I'm now just about to request this.
Derek Johnson
Message 4 of 4
No. If you port your number to a VOIP provider then that will terminate your existing BT package
