Message 1 of 3
Premium phone call list
Should the call list on the premium cordless phones show the calls made and received from the sync mobiles or does it only show calls for the connected landline. Its not clear in the manual.
2 REPLIES 2
Message 2 of 3
Re: Premium phone call list
Hi @Nitramdc
Welcome to the community.
Great question. I believe it only shows calls for the connected landline. It would be interesting to see how yours is working.
Chris
Message 3 of 3
Yes I suspect its only the landline connection. Initially  I was only using the phones with two mobiles  synced and no landline. Absolutely  nothing on the call list. However when connected to a landline  it did  show a record directly connected to the landline but still nothing for mobile calls. I had wondered if the landline connection would sort it all with installed software.
Its a pity the manual doesn't state this. The manual clearly states once a mobile is paired you can not make or receive calls directly from the mobile.  Should also tell you that pairing will sync your contacts but not the call list or explain how to.
