vintman7
Message 11 of 15
Re: Full Fibre To The Property with Digital Voice and Third Party Router
Guru
 Thank you.
The system has a back up battery. The connection was only by the old copper BT line.
No mobile or IP connection- that’s what they are proposing to be fitted for between £600-£1000.
Calls out only come to our mobiles via BT to alert us- not to a call centre.
I can’t see why if power is supplied to their message modem and it’s connected via our internal copper telephone line , into the back of the Hub, while it wouldn’t work.
But I’m just a simple man!!
Devon_Dave
Distinguished Guru
Message 12 of 15
The alarm system probably monitors the line voltage in order to confirm th3 presence of a line in order that it can contact the alarm company if there is an activation.  If you can connect the alarm to the PSTN port on the home hub the alarm should be a happy bunny.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
vintman7
Message 13 of 15
Is the PSTN port the green telephone socket at the back of the Hub?
If so I tried that but when I activated the alarm no message was sent. Hence my thought that a 50v supply would need to be supplied to the modem
Devon_Dave
Distinguished Guru
Message 14 of 15
Did you get a dialling tone when you plugged a phone into the green socket?
vintman7
Message 15 of 15
Yes, I did
