Message 1 of 6
Re: Moving broadband with Digital Voice from BT to EE warning
Greetings,
Regarding moving from Plusnet (BT) to EE Digital Voice, from what I read, there are few good points.
But before I make a decision ( I already have a SIP account - have done for years! )
I would like to ask - what are the costs involved in EE Digital Voice ?
Regards - another old fogie 🙂
5 REPLIES 5
Message 2 of 6
This is a BT forum, you need to ask that on the EE forum.
https://community.ee.co.uk/
Message 3 of 6
So the EE Smart Hub Plus  does not work with the Digital Voice?
Message 4 of 6
Yes it does.
Message 5 of 6
Oh the post suggested EE Smart Hub Plus   didn't work with DV.
Ok as the EE Smart Hub Plus   does work with DV - is it better than the SH3?
Message 6 of 6
Greetings and thanks to all who responded.
As an update. I did not go with the EE package. I stayed with Plusnet - and all my VOIP traffic is routed to a VOIP account I already had, at no extra cost.
I wish you all the best with whatever options you go for.
