Debjdix
Message 1 of 3
Re: Phone not ringing for incoming calls but only when they are number withheld
Hi
i am having exactly the same issue.
withheld numbers make phone click but it does not ring.
BT have checked all my setting and the landline has been checked for faults.
dont know what to do now
2 REPLIES 2
Devon_Dave
Distinguished Guru
Message 2 of 3
Have you tried a known working corded phone into th test point of your main telephone socket?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Debjdix
Message 3 of 3
Thank you.....a bt engineer came out and checked all the line. He left as baffled as we are 😂.
Thank you for trying to help appreciate it
