Message 1 of 6
Registering a BT DECT repeater with a SMART Hub 2
This is a follow up to a previous question. The range on my SMART Hub 2 was insufficient to reach the workshop at the bottom of the garden, so it was suggested I get a BT DECT Repeater.
That I now have done, however I cannot get it to register, so the question is, am I a numpty, or is the repeater at fault? Note, I have 4 phones, all register with the SH2, so it must be transmitting something!
BT SMART Hub 2
BT DECT Repeater - Item Code 064550
I assume any BT DECT Repeater should work? Is that my error? (Don't Assume!!!)
1. Press WPS button on SH2, blue light around button flashes. Plug in the DECT Repeater, red/blue light flashes continuously - never does three blue flashes or steady blue
2. Plug in DECT Repeater, press Setup Button for 5s. Red/blue flashes, never flashes blue 3x or goes a steady blue.
So, is it the repeater (wrong model), the repeater (faulty) or me (Faulty!)?
Cheers
Peter
5 REPLIES 5
Message 2 of 6
Re: Registering a BT DECT repeater with a SMART Hub 2
As far as I'm aware DECT repeaters don't appear to be compatible with the DECT base station built into the hub.
If you use a normal DECT base station plugged into the green socket of the hub rather than using Digital Voice handsets, the repeater should work.
Message 3 of 6
Thank you, 0/10 for compatibility then! In your opinion, could I have a DECT base station (e.g. Diverse 7400) plugged in the green socket, a DECT repeater and a second Diverse 7400 phone in the workshop without the Diverse DECT conflicting with the SMART Hub DECT?
Message 4 of 6
I run a Panasonic base station plugged into the green socket and there is no conflict.  The SH2 DECT is a different frequency.
Message 5 of 6
Yes, I also run a DECT base station as well as DV handsets.
Message 6 of 6
Same here. There's one small issue in that a call answered on the DV handset is likely to show as a missed call on the others.
