Hi,
Can anyone help and confirm the RJ type/shape for the line cable on these two units?
I want to use the existing cable that used to be plugged into the BT76000 base ,and just plug it straight into the new BT4000 but it seems to have a different shape.
Any help appreciated to confirm if the line cable RJ's should be compatible for these two units.
