ceyhan
Message 1 of 7
High everybody.
I am Ceyhan and new for the Community.
I would like to share a recent "scam attempt" I have experienced through my landline...
Someone called Eric Wilson called from  this number  (or claimed to be calling from this number):8044355330
The storry is that I have viruses in my computer and I will turn my computer and delete curtain files...
It became quite apparent to me that something is very fishy here... and did not do anything...
And decided to ask you guys... Did anybody have similar experiences?
Or what is the worst scenario would be if I followed the instructions?!
Thanks a lot in advance.
Kind regards
6 REPLIES 6
Andy005
Recognised Expert
Message 2 of 7
Re: Scam
Hi @ceyhan
This scam has been going on for many years.
Just hang up and NEVER allow anyone to access your computer. They don't, and can't know anything about your computer. All you need to do is to make sure that you have up to date virus protection installed, free or otherwise.
ceyhan
Message 3 of 7
Re: Scam
Hi Andy,
Thanks for swift reply and advice... Much appriciated. Thank you.
I am glad that no damage is done.. I hope that the others will learn from my terrible experiences  too and they will take extra precautions...
Kind regards
Ceyhan.
eth724192021
Message 4 of 7
Re: Scam
How does the scammer know you have got a virus? The name just sounds too simple and it is sus
gg30340
Message 5 of 7
Re: Scam
  • This thread is nearly two years old!
eth724192021
Message 6 of 7
Re: Scam
i just wanted to see what would happen if i got ten posts thats all
gg30340
Message 7 of 7
Re: Scam
So you are resurrecting a post that was marked as solved only to try and improve your standing. I suggest you have a read through the forum rules and guidelines.
BT Community Terms of Use - BT Community
BT Community User Guidelines - BT Community
