Message 1 of 3
Second handset to go with BT Everday Phone with basic call blocking
We've just bought an "BT Everday Phone with basic call blocking" and have decided to get a second to have one upstairs.
Are the BT phones mix and match? Or do I need to buy an identical second handset?
Otherwise I'll just get the cheapest BT cordless handset I can see on Amazon.
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Second handset to go with BT Everday Phone with basic call blocking
To maintain all facilities on the phone, you need the identical additional handset. Any GAP compatible phone will work but likely only to make/receive calls.
Message 3 of 3
thank you
