Gracie2
Message 1 of 11
Sent me Hub but no landline
Hi,
Just wondering, the BT service sent me the hub. When the engineer called he asked if i had the phone sent to me yet but i haven’t. I got the hub over a week ago? Is this something i need to buy on its own?
10 REPLIES 10
Keith_Beddoe
Message 2 of 11
Re: Sent me Hub but no landline
@Gracie2
What sort of broadband connection do you have, it it a direct fibre into your house, with a box on the wall with lots of lights on it?
Could the phone that you are waiting for, be one of the new digital voice phones?
Gracie2
Message 3 of 11
All i know is that they’ve sent me the BT smart hub, i’ve never had wi-fi before (as only just moved out) so i needed an engineer to install the landline. But that’s only as far as what i know. Thanks
Keith_Beddoe
Message 4 of 11
@Gracie2
Do you have a phone socket in the house which looks like one of these?
Gracie2
Message 5 of 11
yes! i have number 2
Keith_Beddoe
Message 6 of 11
Normally you would use your own phone, unless you have purchased on from BT.
When is your broadband due to be activated?
Gracie2
Message 7 of 11
it was activated last week
Keith_Beddoe
Message 8 of 11
BT would not normally supply you with a phone, unless you had placed an order for one. Normally you would buy your own, A basic wired phone costs about £10.
Did you order one as part of your package?
Gracie2
Message 9 of 11
No i haven’t, not that i know of. thanks for letting me know
Keith_Beddoe
Message 10 of 11
If you are not fussed about anything special, then Argos inside Sainsbury, do a basic corded phones, or you can look online.
If you want a cordless one, then they cost a bit more.
You can also look on the BT Shop. https://www.argos.co.uk/browse/technology/telephones-and-accessories/c:29950/
