B13blues
Message 21 of 24
Re: Socket attached to furniture
When you do move it might be worth seeing how near your cabinet is before deciding between adsl or fibre
Barney300
Message 22 of 24
Thanks for the advice B13blues. I'll keep that in mind. At present the cabinet is just outside this block of flats, but I've never had the advertised download speeds, so there's no point paying extra for fibre after the move. I'm used to this now, and I'm not downloading as much as I was a while ago.
Barney300
Message 23 of 24
I just wanted to let NeilO know things have finally been put right. A very well-mannered young (Scandinavian?) man has now properly attached both extensions to the walls.
Problem solved. Thanks to NeilO and all concerned.
NeilO
Moderator
Moderator
Message 24 of 24
@Barney300 Brilliant I'm really glad they got you sorted and I'm sorry it took longer than I expected  Smiley Happy
