Message 1 of 4
Terminating a redundant BT phone extension
How do I terminate a BT telephone extension ? I did chop the wire but had to reinstate as that took out the main phone line? tks
3 REPLIES 3
Message 2 of 4
Re: Terminating a redundant BT phone extension
if you go to your master socket and disconnect cable to terminals 2&5 that should stop extension sockets working assuming you are a BT phone or broadband customer
Message 3 of 4
Many thanks for the prompt reply "Distinguished Sage" : ), I found the wires mentioned (see photo) however having already screwed up one attempt to isolate the extension wire which must loop back to the Master socket (which I did not appreciate), I'm loath to repeat the same mistake hence I will await electricians advice. Best wishes, JeffBT Master.jpg
Message 4 of 4
assuming master wired correctly the the 2 wires visible - white and green - are currently connected to terminals 2&5.  if disconnected that should stop your extension sockets working
