kah22
Message 1 of 8
This number is not in service
I’m a BT customer. Landline and internet.
Today I received a call but didn’t answer it, thinking it was a cold call. The number rang for much longer than your average cold call.
Immediately after the ringing stopped I carried out a 1471 and was given a number beginning with 01259 xxxxxx showing it came from Alloa in Scotland .  Immediately after that I rang the number but got the message ‘sorry this number is not in service,’ even though it had just rang me !
Any ideas as to what this is all about
Kevin
7 REPLIES 7
Andy_N
Distinguished Guru
Message 2 of 8
Re: This number is not in service
Kevin
It's likely to be a scam call from a spoofed number using a VoIP system, not actually from Alloa. Hence the number doesn't actually belong to anyone.
DavidM
Moderator
Moderator
Message 3 of 8
Welcome back @kah22 and thanks for posting.
I think @Andy_N  is spot on here (kudos to you Andy Smiley Wink). This is certainly a scam call and should be ignored.
Cheers
David
kah22
Message 4 of 8
Doesn’t surprise me, though my original thought was a cold call - someone telling I had a virus on my computer or better still there was loads of PPI money I was due 😷
It’s moving away from my original question but can the telecommunication companies and the government not do anything to stop these type of calls, or is is it the price we have to pay for modern technology
Kevin
Andy_N
Distinguished Guru
Message 5 of 8
If it really was that easy, they would have stopped it by now. It's a worldwide issue and with the rise of VoIP systems it's going to get worse in my view, before it gets better. You would hope the telecoms companies are talking together about the issue, but I expect they are all individually doing their own thing to come up with a solution "to be the first".
BT are hoping to replace all their exchanges with VoIP systems by 2025 ...
Starwire
Recognised Expert
Message 6 of 8
BT and other CP’s do block known nuisance numbers but it’s circular, for every number they block the people doing it generate another number to replace it.
It’s like Torrent Sites, ISP’s Block one but within hours there’s 2 or 3 mirror sites to replace it.
kah22
Message 7 of 8
OK guys thanks for your input. What would the general advice be to avoid as many of these calls as possible
At the moment there is really no more than half a dozen call me on my landline; some call give two or three rings, hang up and call back. The rest I’ve started to check via 1471 and if I don’t recognise the number I don’t ring back but that’s a hassle at times
pompey1898
Recognised Expert
Message 8 of 8
BT Call Protect will stop some.  A call barring phone would be the 100% answer.
