Jeff-Gaines
Message 1 of 4
Time on Landline
My 'phone (Gigaest SL 400) hasn't reset the time so I did it manually. Does a BT landline carry a time signal?
3 REPLIES 3
Zombie
Expert
Message 2 of 4
Re: Time on Landline
I’m not sure about that handset, but the majority of phones I’ve had over the years do set the time themselves though I think you need caller display active. If they haven’t changed at the 1am time they normally change the next time an incoming call rings.
Andy_N
Distinguished Guru
Message 3 of 4
Hi, welcome to the forums.
Although a bit late now, if you've not received a call since Sunday morning, then that is probably the reason. It's fairly easy to prove by setting the clock wrong, and then ringing your line from a mobile for example. As mentioned, you will need caller display for this to work.
Do you recall what happened last October when the clocks went back? (assuming you had the phone then).
Jeff-Gaines
Message 4 of 4
Many thanks Zombie & Andy 🙂
One post has been marked as the solution, don't know how but I now know that the time signal CAN be picked up! Will look for a Gigaset forum to see why it wasn't.
