Message 1 of 3
To have digital voice do you need to have fibre installed?
Hi,
I had a letter through the door saying that Digital Voice will be on the way, do  i need to have fibre to get Digital Voice?
Tags (2)
2 REPLIES 2
Message 2 of 3
Re: To have digital voice do you need to have fibre installed?
No
Message 3 of 3
No you don't - digital voice can be delivered perfectly well over broadband carried over existing copper cables.
BT's own publicity for DV has, I think, caused this confusion because it talks about how DV will "retire old fashioned copper cables which are becoming obsolete".
A very large number of houses are likely to stay on fibre to the cabinet, with copper from the cabinet to the house, for a significant time and no amount of changing from analogue phones to DV will change this. BT is retiring the analogue phone equipment at the exchanges, NOT the copper cables!
