Interstella
Message 21 of 22
Re: Transfer a satellite phone number to BT
I finally have fibre broadband Smiley Happy .  I have a minor hiccup with the landline as there appears to be an underground fault with my cable that will be fixed in a day or two but I have 73 Mb/s download, which is great!  Thank you.
I do have a router problem though but I'll start a new thread for this!
JohnC2
Moderator
Moderator
Message 22 of 22
Hi @Interstella Glad everything went nearly smoothly with the connection of your service. I'll close off the case I had open on your account as I wanted to ensure the connection completed ok for you.
Cheers
John
