Message 1 of 3
Transfer numbers from BT8600 to BT3960
hi all,  recently got the BT3960 phone to replace old BT8600
is there an easy way to transfer across the phone numbers,  or is it typing in one at a time
thanks
2 REPLIES 2
Message 2 of 3
Re: Transfer numbers from BT8600 to BT3960
There is no way to export the contacts from the 8600 or any way to import on the 3960, so it's going to have to be re-entry.
Message 3 of 3
appreciate doesnt help with your phones but may for anyone reading
if your on Digital Voice, you can get the EE digital voice phones, they store the contacts on the hub itself and the contacts can be exported and saved to a laptop/pc ie if the hub is changed, the contacts can then be imported from the pc/laptop to the new BT hub and no need to re add them all one by one. ive tried it on the bt sh2 after a reset etc i had to do etc
