Message 1 of 2
Using both a DV phone with Alexa and My Bt cordless Dect phone
I understand that it is possible to plug the old phone into the socket on the back of the Home Hub.  What I am less clear on is whether both phones will ring if there is a call and whether I can choose which I use for any call.  I ask because my wife's work requires  headset use at times and the DV phones do not have this option
1 REPLY 1
Message 2 of 2
Re: Using both a DV phone with Alexa and My Bt cordless Dect phone
both phones will ring on incoming call and you can make outgoing call from either phone.  in addition you have 2 lines with DV and so you can received 2 incoming call at same time or you can make outgoing calls at same time or 1 in 1 out at same time.  if this is not convenient which some have not liked facility you can go to settings calling and change from multi to single so only 1 line and 1 call at a time
