Message 1 of 2
VOIP Phone plus Cordless Phone in same House?
In my new 'All Fibre' Retirement Home I have a VOIP phone set-up (master + slave BT Advanced Digital Home Phones) for my BT landline number, but I also have a BT 'Duet' Corded Phone plugged into a standard wall telephone socket as an internal phone to direct call any other resident in the Retirement Village. This standard wall socket is in an awkward location - in the dining room. Could I install a Cordless twin phone system on this internal line? Would the twin Cordless phones interfere with the twin VOIP phones, and vice versa? If so, is there any other way around this?
1 REPLY 1
Message 2 of 2
Re: VOIP Phone plus Cordless Phone in same House?
Yes it would be possible to install the cordless phone. There should be no reason at all to interfere with the voip phone
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
