Message 1 of 3
VOIP phone
 Does anybody know if a voip phone can be used after pairing with the router as an extension?
2 REPLIES 2
Message 2 of 3
Re: VOIP phone
Don't understand the question, can you be more explicit?
Message 3 of 3
Re: VOIP phone
A VOIP phone is normally plugged into an ethernet port, sounds like you want to pair it with a dect cordless base station  or a Smart Hub which I suspect will not work.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
