accts1234
Message 1 of 7
Live in a small village and lucky to have FTTP installed and now enjoying speeds up to 900mbps instead of 6. When it was installed the Openreach installer said that I still had to keep the existing landline although as far as he was concerned the fibre line would take both internet and phone. The pub about 100 yds away also had FTTP installed but  they also have VOIP installed at same time.
The current landline goes through a windowframe which is about to be replaced so I will need to get it move so that it goes through the wall where the fibre enters. .... but is this really required. Not sure why I can't get VOIP.  BT Sales tell me that it can't be provided. Is that because I am a domestic customer rather than a business customer or is there a technical reason for this?
6 REPLIES 6
imjolly
Message 2 of 7
Re: VOIP
if you go to hub manager - 192.168.1.254 - can you see your phone number shown and is it active?
did you get digital voice phones from BT as part of your order?
accts1234
Message 3 of 7
Re: VOIP
Thank you for replying. Looked at hub manager as you suggested and Phone shows Not Configured.
Thought FTTP meant phone and internet via fibre but perhaps that’s not the case. Wasn’t given the phone option when I placed the order and BT says not available in my area yet-keep calling back to enquire.
imjolly
Message 4 of 7
Re: VOIP
then looks like you need to connect phone to master socket as before
accts1234
Message 5 of 7
Re: VOIP
Thank you for your reply and patience. How do I get this configured?
imjolly
Message 6 of 7
Re: VOIP
if not configured for you area yet then you just need to wait
accts1234
Message 7 of 7
Re: VOIP
Thank you for your help
