ASM987
Message 1 of 3
VoIP Handset Name
Morning
I have 4 VoIP phones connected to my FTTP Smart Hub and I renamed them Lounge - Bedroom - Dining Room - Kitchen all good. Got up yesterday and they had all reverted back to Handset 1 - 2 - 3 - 4  so I changed the names again. Just picked the "Lounge" one up to use and it has reverted back to Handset 3
Anybody know why they are doing this or if there is a fix?
Thx
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: VoIP Handset Name
@ASM987
The phones are DECT, not VOIP.
Can you please clarify, are they all phones supplied by BT for use on their BT Digital Voice service, or are they your own phones which you have registered against the home hub?
A similar thread regarding handset names https://community.bt.com/t5/Home-phone-including-Digital/Problems-with-Digital-Voice-Handsets/td-p/2...
ASM987
Message 3 of 3
Hi Keith
Three of them are the BT Digital Voice VoIP phones, the fourth is the new  BT Alexa Enabled Advanced Digital Home Phone. All supplied by BT for use on their BT Digital Voice service.
