Message 1 of 3
Yealink T46U IP Phones and BT Business Hub
Hi,
My friend has recently purchased Yealink T46U IP Phones from BT Business for his office. He was sent 2 handsets and the 1st handset connected ok to the Business hub via ethernet and he has now plugged in the 2nd handset and connected into Business hub via ethernet but the handset won't connect, is there something he is doing wrong during setup?
Looking through the instructions on the PDF it doesn't mention about plugging in another handset is there any way of doing this or is it only 1 handset per BT Hub and per account?
Any help would be appreciated.
Pete
2 REPLIES 2
Message 2 of 3
Re: Yealink T46U IP Phones and BT Business Hub
@PM75
As this is the BT Residential Customer Forum, you would need to ask your question on the BT Business forum.
https://business.forums.bt.com/
Message 3 of 3
This is the BT residential forum, the business forum is here
