san12345
Message 1 of 6
can't report landline fault
I know it's Christmas Day but I just want to report a landline fault. The BT phone lines are closed. The chatbot has no staff available; the online complaints page is refusing to accept a complaint ("sorry something went wrong" - yeah right) ; there's no email address to send the fault notification to. How is a customer supposed to report a fault on a timely basis in this technological age?
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: can't report landline fault
@san12345
Welcome to this user forum.
You can report a landline fault here https://www.bt.com/help/report-and-track-your-bt-problem
Select "landline" and that will take you to your MyBT login, where you can follow the steps  and report the fault.
san12345
Message 3 of 6
thanks - i've tried this several times but i just get stuck in a loop which has no end to file a fault report
Keith_Beddoe
Message 4 of 6
The script is affected by the result of the line test, so you have to do that first.
If you did that, then what did it say?
san12345
Message 5 of 6
it said contact us to report the fault!
Keith_Beddoe
Message 6 of 6
Never seen that. It normally asks you to check the connection at the master socket and when you have done that, it then gives you the option to raise a fault report, with a warning that there may be an £85 charge if the fault is proven to your own equipment.
It then progressed to the point where it gives you a fault reference and estimated repair time.
I am assuming that you have a normal copper phone line, and not BT Digital Voice?
