Message 1 of 2
changing 1571 settings
When I get a 1571 message it used to just say time the call was received then play the message
It now says the time and then goes on to say the number that was calling before playing the message.
This is infuriating as it takes too long to hear the message, is there a setting somewhere to shorten it, i just want to here when it came and the message
1 REPLY 1
Message 2 of 2
Re: changing 1571 settings
Unfortunately that's not something you can change
