Message 1 of 4
dead line
i do not own a mobile or have internet. I got note of an upgrade a while back but heard nothing since. My brother has told me he  been trying to phone me but it is ringing out with no answer. I do not hear him calling as phone is not ringing. I changed the batteries but still not ringing , indeed when i pic the phone up the line is dead even though there are numbers on phone screen.
I do not know what to do now . My brother brought his phone over and plugged it into my socket with the same result.
Can anyone direct me as to what to do. I am using my brothers pc to write this as i have never had internet or a mobile phone but now feel isolated as i have no way to contact anyone when i am at home
3 REPLIES 3
Message 2 of 4
Re: dead line
Just to clarify, it’s BT you pay for your phone service ?
If you don’t normally have internet access , perhaps you won’t see this reply  , but you need to report your service faulty to your provider , it may be coincidental that your service has gone faulty after you were advised a change to the way the phone service is to be provided is coming, or may be to do with the upgrade to a PDPL (pre digital phone line ) ,either way to get it repaired you need to let your provider know it’s not working .
Message 3 of 4
Re: dead line
yes it is bt i pay for my phone line,i have been a customer for 50 years...so is there a specific number i call to report faults? Will it be on the back of a bill? And you think it may be co incidental that an up grade is happening and my phone has went dead.
As i said i have no internet connection/modem or mobile phone. This is my brothers pc i am using just no
Message 4 of 4
Re: dead line
0800 800 151 is probably the best number to use in your circumstances as presumably you will be calling from an unrelated telephone number .
